In Shop - Race Car Setup, Scaling & Alignment
Started by Ron Sutton, Jan 22, 2026, 03:57 PM
Scaling a Car for Autocross, Track or Road Racing
To get this right, it's a process. Be patient, thorough & accurate. Let's start with getting the scales level & located properly to achieve accurate numbers. I use a what is called a scale platen to roll the cars on that has been leveled in every direction & locked down. Most guys don't have access to something like this, so let's talk about how to properly scale a car on the garage floor.
Tip #1: Take your time & get this right. The info that comes out of this is only as good as the accuracy of the scaling.
Tip #2: Yes, 1/8" is a big deal. I've seen garage floors off 1/2".
Getting the scales ready ...
a. Find spots on the garage floor to match the track width & wheel base of the car. Place the scales in a rectangle on the floor, dead center & square to those measurements.
Using a laser pointer or long, straight, non-bowed, stiff piece of tubing, make sure the scale pads are square to each other. Use blue masking tape to outline the four sides of the scales ... in the exact location they need to be on the floor. Now, during the process, when you knock scales around, you can always go right back to the correct spots.
b. All 4 scale pads need to be at the exact same height.
Using a laser level or long, straight, non-bowed, stiff piece of tubing & a level (digital is preferred as it will be more accurate) ... determine which pad is highest. Then using 16"x16" vinyl floor tile squares (Home Depot?) ... and thin pieces of 16"x16" sheet metal of different thicknesses ... shim the low pads to match the height of the tallest pad.
c. You want the pads themselves to be level too. So if the floor dips so much it causes a scale pad to sit at an angle, you may want to pick another spot, or put shims under the low end.
You want to end up with the scales:
* Centered for track width & wheelbase
* Level & level to each other
* Square to each other & outlined with tape
Grease Plates:
Anytime you jack & lower the front suspension, the tires will "bind" from rubber friction on the scales. This will sometime move the scales ... sometimes not. But it will always give you false ride height & scale numbers. So you need to prevent this "tire bind."
Make four square pieces of thin sheet metal somewhere around 12"x12" to 15"x15". I use .040" thick aluminum, because we have it around the shop often. Put a fine, thin, even film of grease on one side of two plates. Lay another plate on top of the greased up plates ... and you have two sets of "grease plates."
Lay these centered on top of the scales for the front tires. Now you can move the scales (shims & all) out of the way ... roll the car into place so the tires are centered in the tape squares ... jack one side (or one end) of the car up & place the scales in their tape boxes ... repeat on the other side (or other end).
In the real world, the car never ends up centered and the scales and/or grease plates are out of their boxes. Jack & move stuff until the scales are in their boxes & all four tires are centered on the scales & grease plates.
Prepping the car:
a. Put the fuel level in it you plan to compete with.
b. Air the tires up to the pressure you plan to compete with, or at least the same.
c. Put weight in the driver seat to match the driver's weight with helmet & gear.
d. Make sure the tires are dead true straight ahead. If you have toe-out, make sure both are evenly toed out.
e. For now ... unbolt one side of the sway bar linkage, on both front & rear bars, so they don't affect our numbers.
f.  Mark a spot on the frame at all 4 corners where you will measure ride height ... and measure ride height before you start.  Write them down.
Now, you can read the scales & see where you are. Write these numbers down, before you start making adjustments. I suggest you write down all your ride heights, adjustments & scale readings (with dates) from those changes and keep in a file folder. You'll need the info someday.
Ok ... before we make any adjustments ... is the car level side to side?  If not, we need to fix this & the weights together.  Never tweak on the adjusters to "hit a scale #" without keeping the ride heights correct.  I prefer to get the ride heights even side to side ... and the desired rake front to rear ... then tune on the adjusters to achieve my scale numbers.
Here's how ...assuming your ride heights are even side to side:
•    If you need to add cross weight (make the LR & RF heavier) adjust the spring adjusters to raise the LR & RF ... and to lower the RR & LF ... by the same amounts.
•    In other words if you turned the spring adjusters to raise the LR & RF by 1 full turn ... turn the spring adjusters to lower the RR & LF by same 1 full turn.
•    This will keep the ride heights "pretty close".
•    When you get down to the gnat's eye, you'll need to tweak them individually ... but not by much.
•    We almost always keep the ride heights level side to side for road course & autocross competition.  There are exceptions, but not worth discussing here.
We only care about the numbers with the driver ... unless it's going to be a drone.
So for discussion sake, let's say the scales read
LF 1075#    RF 1025#
LR 900#    RR 900#
Results:
3900# Total weight
53.85% Front Weight Bias
50.64% Left Side Weight Bias
49.36% Cross weight or "wedge"
* As a "standard" tuners add up the weights of the LR & RF for a percentage.
This is where tuners differ.  Some will adjust the spring adjusters to achieve 50.0% cross weight.
That would look like this:
LF 1062#    RF 1038#
LR 913#    RR 887#
* Remember, check your corner ride heights.
Results:
3900# Total weight
50.00% Cross weight or "wedge"
The problem with this strategy is the heavier left side weight will make the car roll less & have more grip on left hand corners ... and roll more & have less grip on right hand corners.  An ideal solution would be to physically move weight from the left side of the car to the right side of the car.
Because ultimately an autocross, track car or road race car will perform best if the side-to-side weight bias is 50/50 ... and the cross weight is 50/50.  But for many street cars, that is not practical.  The best "compromise" solution that will produce the best handling (if the left side is heavier) is to run less cross weight than 50%.
I'd love to tell you the formula is XYZ.  But in reality, every car is a bit different.  I do however have a proven rule of thumb.  And that is the cross weight & left side weight need to add up to 100.0%.  So if the car's left side weight (with driver) is 50.6% ... then we need to reduce the cross weight from 50.0% to 49.%.
Hey wait a minute ... that's where we started in this example.  Yup ... the 50.6% Left Side Weight Bias & 49.4% Cross weight kind of balance each other out.  It's just an experienced starting point.  Because you have other factors in your car that may make it have more grip one direction & less grip the other.
So driving it hard in autocross, track or road race competition & tuning it are what I suggest to achieve optimum balance for your car.  More cross weight (heavier loaded LR & RF) will add grip turning left & free the car turning right.  Less cross weight (heavier loaded RR & LF) will add grip turning right & free the car turning left.
You ... and everyone with adjustable spring heights ... have the ability to fine tune this and achieve the best balance.
Future posts will go over more detail.
