Product Spotlight - January 2026
Started by Ron Sutton, Jan 22, 2026, 01:52 PM
Jr. Member
Our complete Sway Bar kits have always been popular with DIY Car Guys, Racers & Fab Shops. When Speedway Engineering closed without notice, I scrambled & researched until I found the best replacement companies & products. Now, Speedway Engineering is back with new owners. they look to be doing good work & are catching up on backlogs of products.
I had utilized Speedway Engineering, with Kenny Sapper running it, for over 25 years. Never thought of shopping around. What I learned when I needed to replace them, was there are, in a few cases, better options. Only a few. But those options are good to add to our sway bar kit lineup.
The biggest things we changed or added are:
  * 1.50" Step-Up Sway Bars over 1.75". They're lighter & achieve the same rates we need.
  * Delrin Bushings instead of Nylon Bushings - Better Lubrication & Life
  * 2.00" Tubular Race-Warrior Sway Bars made with 300M - Super Light & Quick Responding
  * Monoball Bearing bushing for our 2.00" Race-Warrior Sway Bars
  * Offset Sway Bar Arms, Made to Our Specifications - All Sizes
  * Lightweight, Hollow, Chromoly, TIG welded, Race-Warrior Sway Bar Arms
So today, we utilize Speedway Engineering AND the new companies I found to work with. Adding an even more robust line of Sway Bar Kits front & rear.
You can see these in every "Race Car in a Box" package, as well as individually in the Component Kits & Technical Services catalog HERE. See pages 96-131.
