Scope creep '69 Cougar
Started by Ryan Kennedy, Feb 03, 2026, 04:31 AM
Ryan Kennedy
State: TX
City: Fort Worth
Quote from: Ron Sutton on Apr 12, 2026, 01:34 PMThat seat is awesome. One thing Oval track racers do better is prepare to protect them selves WHEN they crash. Too many "Track Car" guys think it won't happen to them, because they're not planning to push the car 102%. Which is rubbish. A crash at 100mph is a a 100mph crash, regardless of intentions.
I caught myself saying something like this. Had to give myself a little pep talk about it basically as soon as I said it. Noone ever "plans" on crashing. It always happens fast and you have no control over it, hence, "lost control". Someone told me to buy the best safety equipment you can afford, and I've tried to make sure I do that.
A carbon HANS would be nice, but a fiberglass HANS will still save your life - you need one even if its not the best of the best. Make sure and install harnesses correctly. Fire suits are expensive anyway you buy them, so buy the best one you can. Fire extinguisher is better than no fire extinguisher, but you can't really use a handheld extinguisher effectively between the moment you realize you're on fire and the moment you're able to do something about it. I'll do a post on my fire system and harnesses. I think I did them as well as I could have, but its a good topic for discussion.
Ryan Kennedy
State: TX
City: Fort Worth
Quote from: Ron Sutton on Apr 12, 2026, 01:46 PMI am a fan of the both the Fuel Lab brand & Radium Engineering brand of Top Plate systems with Fuel Cell Surge Tanks.  They only cost a little bit more money than running the square collector in the bottom of the tank.  They pickup more fuel, increasing how far we can run on the same number of gallons.
FuelSafe told me the Radium Engineering brand is hard to get sometimes. So they use the Fuel Lab brand more.
Deatschwerks also did their own version with a fabricated aluminum surge tank that serves as a top hat for the cell as well, so there's definitely options for keep it all contained in the cell. External surge tanks are also an option.
I helped a friend make an external version for his car since he was having starvation issues. It incorporated a box style in the cell to an external surge tank the fed the primary pump. The fuel return from the rail ran to the surge tank and then the surge tank had an overflow back to the cell into the box style internal surge tank. Extra component or two, but he really liked his hat and primary pump setup and didn't want to change it. We were able to make the external surge tank to a size and shape that worked best for the space available. Worked great! Solved the starvation issue. Didn't do anything more for using every drop of fuel in the cell, but doing time trials with short sessions on track, it wasn't an issue.
Quote from: Ryan Kennedy on Apr 13, 2026, 12:13 PM
Something not common knowledge is all SFI suits come with a TPP rating.  The SFI numbers themselves can be a little vague. But the TPP number is clear.  Every TPP point is 1/2 second before the fire burns through the suit & gets you.  Have a 22 TPP suit? You have 11 seconds from the time the fire reaches you until you are burnt. 26 TPP = 13 seconds.  NASCAR requires a 39 TPP = 19.5 seconds.
I'm telling you from experience, if your car catches on fire above 120mph, it is hard to get stopped in 11-13 seconds.  If you crash (or someone crashes you) & the race car catches fire ... 11-13 seconds happens long before the safety guys reach you.  Buy the best suit you can afford, with the highest TPP rating.
Ryan Kennedy
State: TX
City: Fort Worth
Seems like a good time to talk about fire suppression! I went with a 10lb SPA Extreme Novec system. I would like to add a second system, but for now, this is what I have.
 AFFF is the other common option, and is less expensive. Being a foam system, the chemical must be applied directly to the area on fire. Novec (3M) or FE-36 (Dupont's halon replacement) is deployed as a gas and moves around obstructions.
The SPA system I purchased uses a 5/16" rigid tubing of which they don't include nearly enough of so you'll end up buying more, but makes for a cleaner install. installation of the plastic coated AL tubing used in the AFFF systems I've seen, is much easier. The coated tubing bends by hand, and there's usually enough of it included with the system for the entire car if properly planned.
Despite the Cougar being a large car, real estate was running out. Bottle location was limited to the only available cage tube. Found a nice used pair of mounting brackets for about a quarter of what they are new.
Most manual systems only come with one pull cable so I had to find a place I can reach it belted in, as well as crew.
It may look awkward but I can reach it with either hand and have adequate force to pull and its easily used by crew. Side note - I changed away from the multi-angle wink mirror after the first drive and opted for a wide convex mirror. That kind of thing is personal, but the mounting of the wink mirror was difficult with my layout, and the vertical visual field felt limiting.
Now for nozzles. I system came with four nozzles. I pointed one at the top of the fuel cell, one at driver feet/legs, one at passenger legs and plumbing as a secondary, and the rear of the intake manifold.
The fuel cell nozzle can be seen in my fuel system pics and you can see the backside of the engine bay nozzle in the interior.
